front left/right speakers
Discussion in 'Home Cinema Speakers' started by gavtheskav, Jun 24, 2004.
  1. gavtheskav
    gavtheskav
    hi does anybody hear have there front left/right speakers at ceiling level? :nono:
    its just that there isnt any room left at the side of the television as the window is there, i do know that for the best sound they should be ear height when your sat down.
    if anybody does, at what space do you have them apart?
    thanks.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    The problem with that is where you have your centre speaker. if you also have the centre speaker at ceiling height it will be so far removed from the screen that the sound will not be pinned to the screen and will seem disjointed. Likewise if you put it on top of the TV it will be so far below the other two speakers that it will still sound disjointed.
  3. gavtheskav
    gavtheskav
    the centre speaker is built in to the set
  4. Zone
    Zone
    Jun 24, 2001
    6,712
    Barnsley
    +2,389
    OK A little more info needed then!
    What left and right speakers are we talking about here if the centre is located in the "the set".
  5. gavtheskav
    gavtheskav
    er the set is a toshiba 36zp38 and the front speakers are the one that come with it, they are little skiny things but sound ok when played with the dvd dd
