Front LED / VFD thing
Discussion in 'Microsoft Windows' started by Rambles, Oct 21, 2005.
  1. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    To save me some time trawling the net, does anyone fancy answering some questions on this for me :lease: . I have a Shuttle SN41G2V2 and am not using the floppy bay for a floppy so wondered if I could stick a little LED display in there and hoping it would display lots of useful info when using MCE..
    Questions....
    1/ Are these little displays compatible with all motherboards, or only some?
    2/ How do they connect to the mobo?
    3/ Do they use much power?
    4/ Can I literally stick it on the outside of the case, maybe overlapping the floppy bay?
    5/ How much are they?
    6/ What info will it display - I would particularly like it to display some live tv info (channel maybe program name) and whilst watching video the amount of time into the video you are, and amount of time left remaining.
  2. Kramer
    Kramer
    See 2.
    Usually serial or USB.
    Usually powered from a spare floppy drive or molex connector
    Depends on the type/model of VFD/LCD.
    £20/30/40......Not too expensive really.
    Depends on the software/plugins you use. They are very customisable though.
    I have a 4 line Matrix Orbital LCD on one of my PCs. Been working for years & is dead cool :).
    That's a start anyway.
    :smoke:
  3. Werner
    Werner
    I am more of a parallel port guy, so here goes my take
    anymotherboard that has a parallel port
    parallel port
    nope, very little..powered form 5v molex connector
    no harm done, it is just a size thing...does it physically fit? a 2 x20/ 2 x16 will easily fit in a 3.5" bay
    homemade, £5..buy from shop, £30-£50
    any signal that the msas (media state aggregator service) can send out via mce can be captured and displayed on the display...channel name, time remaining, id3 tags, picture names, transport state (pause, play record, rewind etc)
    software: frontview for mce
    http://www.mediacentermagic.com/
    hitachi front panel display:
    http://wiki.shahine.com/default.aspx/MyWiki.HitachiFrontPanelDisplayForMediaCenter
    some sample tags that can be displayed (of course, the application will format it properly)
    http://msdn.microsoft.com/library/d...SDK/htm/mediastatuspropertytagenumeration.asp
    something like this
    http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=137424
    fits in a 5.25" bay, and gives you a 2x16 vfd display (much better than lcd) which works with the software mentioned above.
    some people think displays are a trinket, a novelty, but for me it adds the finishing touch to an htpc.
    enjoy
  4. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    I want one - thanks for the info :thumbsup:
  5. cbemoore
    cbemoore
    May 16, 2002
    1,300
    38
    Esher
    +16
    Sounds interesting! How easy is it to make a home-made one? And where do you get the bits?
    Chris
  6. Kramer
    Kramer
    Yep, a VFD is definitely the way to go for a Media Centre/HCPC.
    :smoke:
  7. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    Just taken my shuttle apart and it will not go in the floppy drive bay, cos my hard drives take up all the space. So, maybe I can get a freestanding display that can go on top of, or next to the pc?
    Will do more research but if anyone knows of something that may be suitable, please let me know - thanks
  8. DaveP
    DaveP
    I think a 5.25" external USB case would do the trick. It would give you the molex power and you could modify it slightly to connect to your external parallel/usb/serial port. I picked up one secondhand for a tenner but you can get them new for about £25.
    You'd have to bin the usb to ide interface of course
    Dave
  9. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    That's a good idea... however just re-read werners post and he has given me a link to a ready made one at scan (Silverstone) - it connects via parallel, which I haven't got, but it seems the motherboard does have a parrallel header, just need to get the cable and it looks like I will be ok :)
  10. DaveP
    DaveP
    I was thinking of this:
    My mistake then, If it is this one I thought it needed a spare 5.25" bay
  11. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    Yes it does - which I haven't got, but thought maybe i could just have it next to or on top of my shuttle?
    I may be able to squeeze a display into the floppy bay, but it will be really tricky because I have the dvd drive and two hard drives in there, and they are all in a fitted cage - which means it will probably need a hacksaw to make it fit :rolleyes:
  12. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    You could alwasy go for an Itron display, and put in in a 5 1/4 bay window or do an external mod on it...
    [​IMG]
    [​IMG]
    Link
    You won't get a better diaplay than a custom built one...
  13. Werner
    Werner
    the display is one thing, but as lisa has mce, it would need some form of mce support.
    Graphical lcd's are all well as fine (I have a few running on a sed1520) but with no mce support they may as well be bricks
  14. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    Well thanks again for all the help, think I will go for the Silverstone one - £60 delivered in a nice aluminium CD drive sized case, so can use externally... or I can take the display out of the enclosure and try and fit it in the shuttle - best of both worlds :)
  15. Werner
    Werner
    search ebay for "hd44780" (that is the industry standard chip used in these things...for parallel port goodness)
    currently, there are some nice ones in the <£10 range.
    if you want 4 lines of display then this unit is pre-wired and just ripe for modding
    http://cgi.ebay.co.uk/character-lcd...ryZ75520QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    wiring guides are all over the place, but, essentially you need a printer cable to cut apart, wire up 14 wires (or 16 if you have a backlit version whcih is recommended) and bob's your uncle
    some guides here
    http://www.overclockers.com.au/techstuff/a_diy_lcd/
    that is pretty much what the silverstone unit (and others) amounts to...a hd44780 compatable backlit 16x2 lcd/vfd with parallel cable attached.
  16. sprout
    sprout
    Dec 15, 2002
    6,567
    Bridwater Somerset M5 Junction 23/24
    +290
  17. fraggle
    fraggle
    Dec 11, 2002
    1,516
    Sugar Land, Texas
    +58
    The Silverstone units use iMon units which are USB, not parallel.
    The iMon unit I've got in mine also has a built in IR receiver (and I got the matching remote to go with it) with which I can control MCE, DScaler, etc, etc.
  18. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    I think you are mistaken - this is what I have ordered Silverstone it uses a 25 pin parallell port.
  19. Werner
    Werner
    the silverstone standalone thing lisa has ordered is hd44780 parallel. The lc03-vfd case is hd44780 parallel. I believe the newer lc-xx series have imon compatable displays and optional remote receivers.
    we are both right:)
  20. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
    Lisa,
    When you get this working can you let me know how it all works, goes together, is cabled etc. I am quite keen on one of these as I could put the diplay up by the plasma and leave the PC tucked away.
    I'll be particularly interested to know if you need the parallel port adapter for the back of the Shuttle or if you can wire it directly to the header on the motherboard.
    Cheers in advance.
    Mark
  21. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    ;) Fair enough - do you mean the VFD's already fitted in the cases are imon?
  22. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    Sure - providing I can get it working... will even take some pics if you want! I have ordered the Shuttle parallel cable, only £5 delivered from Micro Direct and thought it would make things a lot simpler....
  23. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
    It is the "Getting it working" part I am most interested in! :D
    I figured I would let you do the hard work and then let me know how to do it! :smashin:
    It'll be nice to let someone else be the trail blazer for a change lol.
  24. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    Gee - thanks, hope you are not in a hurry.... :rolleyes:
  25. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
    Always happy to wait for you Lisa, tomorrow will be fine! :)
  26. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    let us know on the viewing distance, and the stuff you can do with eg..eg show you your system status/medi playing...be interesting to see all the stuff oyu can do with it, and how you go about setting it up...
  27. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    Yes, me too - I am wondering if it is going to be too small to read from a distance, and whether I will actually get any useful info on it within MCE... fingers crossed..
  28. sprout
    sprout
    Dec 15, 2002
    6,567
    +290
    This look quite good for a stnd alone setup on ebay 5791456022
  29. Rambles
    Rambles
    Jul 14, 2004
    10,527
    167
    UK
    +2,205
    Shame I never got round to taking that German electronics degree :)
  30. sprout
    sprout
    Dec 15, 2002
    6,567
    +290
    Why do you need German? It is electronics :D
