From Samsung LE40B650 to UE40ES5500
Discussion in 'Samsung TVs Forum' started by Krillian, Sep 10, 2012.
Tags:
  1. Krillian
    Krillian
    Sep 10, 2012
    3
    Hi all,
    I had a Samsung LE40B650 which recently broke, fortunately it was still under warranty.
    The same model is no longer available, so they offered me a UE40ES5500.
    Is this a good switch, or should I be asking for something else within the similar price range?
    The warranty company are JTM Contracts LTD if that helps.
    Any advice would be very much appreciated.
    Thank you very much in advance!
    ~Krillian
  2. aaedwards
    aaedwards
    Feb 10, 2009
    111
    +6
    Hi i would look for something else as the ES5500 uses a cheaper panel (Screen) than you B650. i did have the ES6300 which i returned because it looked washed out. i would checkout the new Sony KDL40HX753 which uses the SPVA panel which is similar to the one that was in you B650 and has the bonus of 3D hope this helps regards Anthony
