from ipod to hard drive
Discussion in 'Headphones, Earphones & Portable Music' started by iZombine, Jan 24, 2005.
Tags:
  1. iZombine
    iZombine
    Jan 21, 2005
    870
    28
    +33
    Is it possible to copy songs from my ipod on to my laptop hard drive?
    If yes, is there any free software that will make it possible.
    Thanks :thumbsup:
  2. mick's cat
    mick's cat
    Yes it's possible. Go to:
    http://www.versiontracker.com
    and do a search for 'ipod' - under the Windows tab if you have a PC, or under the MacOSX tab if you have a Mac. You'll see loads of iPod utilities, to do what you want, and to do loads of other things too.
  3. iZombine
    iZombine
    Jan 21, 2005
    870
    28
    +33
    Just downloaded a program from there called PodUtil and it works great.
    Thanks very much :thumbsup:
