From dvd to dvd recorder HDD?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kasparaitis, Oct 11, 2004.
  1. Kasparaitis
    Kasparaitis
    Is it possible to upload dvds from disk to the dvd recorder HDD?
    I would like to do this so I can edit them.
    Thanks.
  2. scoutthedoggie
    scoutthedoggie
    My mates Pioneer 520 can do this, dunno about any others
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    The Pioneer can only copy -R to HDD in real time if editing is needed.It can do a high speed clone disc but without editing.
    I think Panasonic machines only allow RAM to copy to HDD.
    I would think any machine would enable a connection between Scart output and Scart input.Playing dvd while HDD records should be standard,although results may not be as good as the internal copying
  4. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    You can on the Pan 85. I would assume you can on all Pan models with a hdd.
  5. F G Evans
    F G Evans
    Can this be done on the Tosh RDXS32
  6. Benfica
    Benfica
    You are no asking about original DVDs, are you ?
    Cause if you are, the answer is NO.
    In this case there are some workarounds, but I'm not the best person to talk about them.
    Best regards
  7. Kasparaitis
    Kasparaitis
    I would like to put dvds I have made on my PC onto the dvd recorder hard drive.
    Is this possible with a Toshiba Rdxs32.
  8. tdale
    tdale
    My Panasonic E85 can. It doesnt support reading DVDRW, but it does.
    You wont be able to copy commercial, protected DVD's unless you copy them with DVDShrink.
