From component video to scart?
Discussion in 'Cables & Switches' started by isko, Aug 30, 2004.
  1. isko
    isko
    Aug 29, 2004
    26
    Is there a cable( or a group of cables or equipments) which will connect the component video output on the rear of Yamaha RX-V740 AV Receiver to scart input on the rear of Philips 36" TV? Thanks for everybody's help. :confused:
  2. fatbob
    fatbob
    May 22, 2003
    267
    19
    There are cables that have component connectors on one end and a scart connection on the other, but your main problem is that Philips tv's don't accept component video, so I'm afraid that a lead of this type won't be of any use to you.
    The signals which your tv will accept through its' scart are RGB, s-video and composite.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,442
    The Borders
    +2,596
  4. isko
    isko
    Aug 29, 2004
    26
  5. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Nope. RGB and component (aka YUV) are not compatible, even though the color of the YUV connectors implies otherwise. Said adapter is used for TVs that allow YUV via Scart, like e.g. some Loewe models.
    Note: Technically speaking RGB is also a component signal, but the term 'component' usually refers to the YUV connection only. :lesson:
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,442
    The Borders
    +2,596
    isko
    Interfacing the 3 core YUV to a 4 Core RGB + Composite sync SCART Input is not a Pin to Pin job - there's active signal Transcoding to be undertaken; do it on the cheap and kiss goodbye to image quality.
    I doubt you'll get something anywhere near the Kramer quality for the same price - in a TV studio you'd be spending a few £k to do the same conversion.
    Best regards
    Joe.
