Friday Night Install
Discussion in 'Computer Software & Operating Systems' started by HDPete, May 4, 2007.
  1. HDPete
    HDPete
    Jan 15, 2004
    281
    Ringwood, Hampshire / Dorset Border
    +14
    I haven't been drinking... yet...
    I have installed otheros and rebooted with the YDL DVD in the drive. It goes through the various text startup screens and pauses at kboot.
    If I then leave it, it boots into Anaconda installation where I can select the Keyboard layout. The mouse and keyboard are functioning at this point.
    When I select 'Next', the button is pressed in but remains pressed and the installation doesn't go any further. I can't go 'back'. If I press the power button on the PS3, YDL carries out a graceful shutdown - so it hasn't completely frozen.
    What am I doing wrong?
    :lease:
  2. HDPete
    HDPete
    Jan 15, 2004
    281
    +14
    Further info:
    The USB drive has the otheros.bld & otheros.self in the \ps3\otheros directory.
    There isn't a network connection. The latest attempt at instal has frozen at the 'Loading gelic_net driver...' screen.
    Could it be a lack of n/wk causing this?
  3. KevB_UK
    KevB_UK
    Lack of network should be fine, v5.0 installed for me like that. Maybe a bad download or burn?
  4. HDPete
    HDPete
    Jan 15, 2004
    281
    +14
    I'm going through a full format of the HDD, whereas I did Quick format before. Don't think it'll make a difference, but at least I know it's completely fresh.
    The keyboard is a PS2 keyboard going through a ps2 to usb converter. It's all just serial signals and the keyboard works up until the 'Next' screen.
    Will try a direct USB keyboard tomorrow (after the format completes (3h55m!!)).
    Thanks for your help
  5. small358786
    small358786
    Mar 17, 2007
    1,195
    48
    +83
    The format type makes no difference,it just seems your keyboard isn't recognised by Linux.
