freq response
Discussion in 'Home Cinema Speakers' started by hitz, Jan 10, 2002.
  1. hitz
    hitz
    Dec 18, 2001
    68
    Whats the difference between frequency repsonse and frequency range?
    What do they mean.? Should i take any note of them when comparing on paper. I realise that listening to them is the best option - but to get a shortlist - what should i look out for when choosing speakers ? (i.e. fronts)
  2. Lowrider
    Lowrider
    I think it is the same...
    1 - The best sound, if possible in similar conditions as you will use them (equipment, placing),
    2 - the nicest looks (unless they are closed in a cabinet ;) ),
    3 - good brand (reliable, after sales service)...
  3. bob007
    bob007
    Both mean the same.
    When looking at the figures eg....... 45hz-20000khz
    45hz is the low frequencies (bass) 20000khz high frequencies (treble)
    Are you going to include a sub in you setup?
    If so this will do for the really low bass your speakers won't produce.
    M73 L/F range is about 45hz. This may be enough bass for some people but not enough for others.
    As you said have a demo, only you can tell if the speaker sounds right and has the amount of bass you require.
    It's not all about bass, mid-range and treble are important too.
    Are your speakers going to be for music, movies or both?
