French subtitles on American Films ?
Discussion in 'Movie Forum' started by FoxyMulder, Jun 17, 2004.
  1. FoxyMulder
    FoxyMulder
  2. ebury
    ebury
    Nov 5, 2002
    1,268
    41
    london
    +12
    foxy,
    Very good company but be careful with the shipping methods.If you go with the lowest,you have no come back if the title doesnt turn up!!
    with regards the subbs',usually at the bottom of each titles listings they list if the subbs are burnt in or removable.check 12 monkeys and it says "french subbtitles always on when using english soundtrack"
    Always found this company reasonable with some very specials if you keep checking
  3. inzaman
    inzaman
    Dec 16, 2002
    7,966
    Derby
    +1,034
    Very good company had a few items from there myself. As for the subs they are more than likely imposed but you can turn them off, dvd player dependant. I can turn them off with my pio 757, if you do a search on this site then you will find a very good thread with instructions on how to do it.
