Freezing on channels every five seconds
Discussion in 'Satellite TV, Sky TV & FreeSat' started by OurJud, Jul 31, 2012.
  1. OurJud
    OurJud
    Nov 12, 2008
    89
    Developed an odd glitch since yesterday. I have one of the newer Sky+ HD boxes after I had an engineer come out to fix a separate issue a few weeks ago. I know it's one of the newer ones because I'm the only one in my family with the new-look planner. Anyway, yesterday all the Sky channels started to freeze up every five seconds or so. Then they'd unfreeze, play for another five seconds and freeze up again. This would just repeat continuously. freeze, unfreeze, freeze, unfreeze.
    The free-to-air channels are fine.
    It's the only box in the house and I do not share with anyone.
    I've done a reboot which seems to have resolved the issue for now, but I suspect it will return.
    Is this a known fault and are there any permanent fixes? Thanks in advance.
  2. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    It's not known, in the sense that it's the first time it's been reported here.
    Machines do go wrong though, and so can Sky subscription cards, so it's up to them to fix the problem.
  3. OurJud
    OurJud
    Nov 12, 2008
    89
    Thanks, logicel. I will get on to them if the problem returns, just wondered if others had experienced it and had any answers.
  4. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    If it is only Sky channels then, as Logi suggested, it sounds like a card problem. Try removing it, cleaning the contacts with a dry cloth, and re-inserting it.
  5. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    That's OK, and we do get a variety of problems but this one hasn't come up before. It does sound like the card.
  6. OurJud
    OurJud
    Nov 12, 2008
    89
    Thanks very much to you both. Still okay after the reboot this morning, although I have been out all day and only just got back.
    Anyway, I shall try the card cleaning if it returns, and if that doesn't fix it, contact Sky - it is a very very old card now.
    Thanks again.
