Freezes when AHCI is used.
WibXL
I'm currently using the 64bit version of Windows 7 and have noticed a strange behaviour when AHCI is switched on in the BIOS. Whenever one of my HDD goes to sleep or wakes up Win7 will freeze up for a couple of seconds but it doesn't do this when AHCI is turned off.
It's not a huge problem although it can be annoying when it happens during a game. Anybody else suffer from this and did you find a solution other than changing the power options for your HDDs?
Stiggy
You're not supposed to switch between IDE and AHCI modes. Windows often needs a complete reinstall which you switch - it's a wonder yours works at all!
WibXL
Pretty sure that I originally had it turned on but a reinstall wont hurt and should get rid of a few of the cobwebs in my system.
WibXL
All's well after a reinstall so either I didn't originally have it turned on in the BIOS when Win7 was installed or the new mobo drivers I downloaded fixed it.
