Freeview
Discussion in 'Freeview & YouView' started by thamesider, Mar 28, 2003.
  1. thamesider
    thamesider
    Advice needed for a mate please:-
    Which is the best freeview box make?
    Total cost to get installed?
    Best people to install it?
    Do you get teletext on the freeview channels?
    Thanks in advance:)
  2. shawkins002
    shawkins002
    Dec 12, 2002
    236
    Epsom, Surrey
    Which is the best freeview box make? - Nokia 221T. No question in my opinion. Retails at about £120 - worth the extra £20 or so over the other boxes on the market.
    Total cost to get installed? - Nothing if your aerial's up to it - if not, around £60 for an aerial upgrade, depending on the difficulty, where you live etc. Have you checked the postcode checker on the Freeview Website for your coverage?
    Best people to install it? - Check the yellow pages for local aerial installers.
    Do you get teletext on the freeview channels? Yes - digital text is available on the BBC channels, and the teletext channel isn't a bad service. Whether digital text is better than analogue text is debatable - personally prefer the old service, despite the cr*p graphics. Digital text is improving though.
    Simon
  3. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Note of advice, re. Teletext - leave the 5 terrestrial channels tuned in on channels 1 to 5 of your telly so that you may access teletext when you wish.
    I got the aerial man to give me spiffing Analogue AND digital reception and I am very impressed.
    Nokia 221T - he commented that this was a really good box - wasn't familiar with it, but while he was messing with the menus for setup he commented positively.
  4. DJM
    DJM
    Dec 10, 2002
    167
    +4
    April What video compares the freeview boxes on the market and rates Nokia 221T as the best. It's certainly easy to use. Plug in press install and watch TV - job done.
