FreeView with s video, cheap as possible
Discussion in 'Freeview & YouView' started by Sh4rk, Jun 6, 2005.
  1. Sh4rk
    Sh4rk
    Apr 13, 2004
    92
    Winchester
    As Title. I am looking for a cheap Freeview box with s video output, as cheap as possible. Optical output for audio would be good as well.
    Also, could you recommend a cheap portable aerial.
  2. Sh4rk
    Sh4rk
    Apr 13, 2004
    92
    Winchester
    No one got any ideas?
  3. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I think the silence is due to there not being such a thing. Look at this list
    I am not an expert in these boxes but as far as I can see you have to be in PVR territory before you get s-video options eg pace Twin and Topfield.
    Why do you want s-video? It is inferior to RGB through a scart (usually). Have you run out of scarts; why not use a splitter or daisy chain your kit?
    Regards Richard
  4. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    S-video is available from numerous (non-DVR) Freeview STB including the Sony and Pioneer.
    Unfortunately, neither of these are at the 'value' end of the market. I'm fairly confident s-video output can be had from cheaper boxes too but I have no personal experience of any of them so can't make a recommendation.
  5. Seft
    Seft
    Mar 17, 2004
    misspost
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    some of the cheaper boxes have S-video via scart on the TV out assuming you want 1 S-video out not RGB and S-video out just look at boxes in your pricerange and check specs for S-video out.
    As for portable aerial, is this for Freeview? you will probaly struggle unless very very close to transmitter
  7. Sh4rk
    Sh4rk
    Apr 13, 2004
    92
    Winchester
    The reason for s video is that my tft doesn't have scart. It only has DVI VGA composite and s video. Yes the portable aerial would be for freeview. Is there any way to check how close i am to a transmitter? Any suggestions on the best aerial so that i can try it out?
  8. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    For local transmitter info, give the Wolfbane site a try. Just enter your postcode.
