Freeview with RF output?
Discussion in 'Freeview & YouView' started by CH3, May 13, 2005.
  1. CH3
    CH3
    Jun 27, 2002
    169
    +7
    Just got a Philips DTR500 freeview box for someone, and discovered that although it has an aerial pass through, it doesn't actually put the freeview channels out on this connection. This is fine except the person it is for doesn't have scart on their TV!
    Is there a freeview box that does this and has selectable channel output so that it doesn't clash with the video on the same aerial lead? The old Ondigital box did this great, but it's not so great on the Interactive bits we want.
    Help!
  2. Supernatural
    Supernatural
    Nov 15, 2003
    326
    Aldershot
    +5
  3. CH3
    CH3
    Jun 27, 2002
    169
    +7
    Thanks. Definitely a freeview box wanted, otherwise it's 2 boxes if u see what I mean..
  4. simon123
    simon123
    May 14, 2003
    296
    +7
    pace,thompson with or without top up ,nokia,panasonic,strong,triax,daewoo i think.
    i recomend the pace if you can get hold of one,then panasonic then thompson
    but they all work
  5. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    pioneer dtf100 also has rf modulator although it is discontinued. means there will be bargains :D
