freeview with component output
Discussion in 'Freeview & YouView' started by roofer, Jan 14, 2004.
  1. roofer
    roofer
    Nov 21, 2002
    343
    northumberland
    +10
    i need a freeview box with component output can any one tell me if their is any available at present and where to buy from? cheers
  2. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    The Netgem iPlayer is, afaik, the only one that'll do it. Damn good freeview box to boot.
    clickety click
    Cheers, Carl.
  3. roofer
    roofer
    Nov 21, 2002
    343
    northumberland
    +10
    cheers for the swift reply, had a look at the netgem but it does not say it supports component out.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    it does via a software menu and an adapter cable that comes with it IIRC
  5. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    Software option to configure component out, and then an RGB Scart to YUV cable - not a Syncblaster-type conversion cable, just a straight through cable. It's not supplied with the right cable, but they're easy to pick-up (got mine from av-sales.com, Joe @ TMF does 'em too).
    Cheers, Carl.
  6. roofer
    roofer
    Nov 21, 2002
    343
    northumberland
    +10
    thanks for the advice will get a netgem tomorrow from johnlewis at newcastle .
  7. monopole
    monopole
  8. roofer
    roofer
    Nov 21, 2002
    343
    northumberland
    +10
    hooked up my netgem via a scart to component lead vivanco from john lewis phoned newcastle seven oaks the guy their said their was no such cable, and it would never work, but it works a treat once you configure the setup menu, now i can do away with my faulty plasma tuner box which was turning the picture green thanks for everyones help cheers martin.
