Freeview vs. E85
Discussion in 'Blu-ray & DVD Players & Recorders' started by wilby, May 26, 2004.
  1. wilby
    wilby
    Jun 27, 2002
    58
    Yorkshire
    Eventually got the E85 hooed up thus
    aerial
    wall > Panny digibox > E85 > Panny Vid > Sony TV
    Connections
    Digibox > to AV2 of E85 (set to RGB in & "normal") > E85 AV1 RCB out > TV
    I was having terrible trouble trying to get a looped through signal from the Digibox, so much so that I've had to tune the TV to accept an aerial signal using ch68 ! This was the only way I could get (say BBC3) whne the E85 was recording.
    Any suggestion of a solution? or is the best I can hope to get?
    Other than that it's a stonking machine, and I can't believe I put up with video (with its forward fasting & rewinding) for soooooo long.
    Wilby
  2. Kevo
    Kevo
    Aug 23, 2001
    5,466
    Manchester
    +168
    :confused: I don't think you (or the rest of us) had any other choice until recently!
    Regarding the loop thru issue...
    This is the same on all the Pannies I think.
    You can't watch another channel through the recorder whilst recording another.
    On my E100 I go via the VCR SCART out on the stb via my VCR and watch this way when recording. You should be able to so the same which should give you a better picture than the RF method that you are using.
  3. cuewoz1
    cuewoz1
    Oct 30, 2003
    187
    does it have pass through signal when you don't record?
    I am thinking of these to go
    sky digibox>TiVo>E85>Tv
    would I be able to have this set up?
    Or is there a better way to include the Tivo.
    I want the E85 for a better hard drive resolution as I am not that impressed with tivos best quality compared to direct sky feed. I want to use tivo still because its a good PVR. but for series I want to put on DVD I want to record them on the E85 then transfer to disc.
  4. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    There was a thread before about this problem with the e30 or e50. The solution was to change the rf pass-through on the box from channel 69 to something which won't disrupt the digibox (make sure its not messing up your analouge or sky picture either). The reason I think its unaffected when its recording is because the rf pass-through is disabled.
    Rich
  5. Kevo
    Kevo
    Aug 23, 2001
    5,466
    Manchester
    +168
    Yes and when in standby mode.
