Freeview viewing problem
Discussion in 'Plasma TVs' started by crobo, Jun 14, 2005.
  1. crobo
    crobo
    Mar 10, 2004
    3,108
    83
    +115
    Can anyone help on this one? I have been running a SKY digibox into a JS RGB-VGA converter, which then goes into a Lumagen vision (older analogue model) and into the Panasonic pwd4. This worked fine. We are getting freeview instead and the installer put up a new aerial and tested it with the receiver he brought. I connected the scart to the JS box and the picture was terrible - very jumpy.
    Nothing wrong with the reception - the same RGB scart worked great connected to either a normal CRT TV or the input of my Toshiba DVD recorder (which then links to the S-video input of the Lumagen). So something about the JS box - Lumagen - plasma run is giving problems. Any suggestions anyone? I tried changing the basic controls on the Lumagen but to no avail. I don't want to choose a freeview box until I know what the problem is, and I'd rather not use the input for the DVD recorder unless I have to.
    Thanks in advance
