Freeview VCR
Discussion in 'Digital TV & Video Players & Recorders' started by scrapbook, Jul 10, 2004.
Tags:
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    Hi there.
    Can any one point me in the direction of a VCR with built in Freevie tuner?
  2. Crocodile
    Crocodile
    Nov 4, 2002
    18,325
    +6,858
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
  4. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    With the Freeview PVR's I assumed I wouldn't be able to tape, say, from my NTL box?
    Is that correct?
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    No you will need a Tivo or a DVD recorder - lots have hard disks in now - but this is not a bitstream record.
    Vhs is dead - time to forget it!
  6. Bigweed
    Bigweed
    May 5, 2004
    120
    16
    Bournemouth, UK
    Hi, what is a bitstream output?
    Bigweed
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,311
    Rainham Essex
    +2,425
    'Bitstream' is the digital signal before being converted to analogue for watching on a standard analogue screen. Recording the bitstream would give a better quality picture, but if the decoding & encoding is done well then there should be very little noticeable difference from a bitstream recording.
    TiVo is often knocked for only recording from an analogue input but IMHO the quality is better than most people will be able to see on a 32" TV etc. Even on my 37" plasma the difference from the origional feed from my Freeview box and via the TiVo is just about unnoticeable. If you can notice it then there are 'hacks' available for TiVo to up the bitrate to improve the PQ further.
    TiVo is the way I would recommend you going as it is the only PVR that will record from all the UK TV platforms. If you don't want a PVR and just want to record the soaps etc then get a standard VCR and separate Freeview box as this will be cheaper - Freeview boxes from around £30 & VCR's from around £60. When one dies you just replace the dead unit & not the whole lot!
    Mark.
