Freeview V Sky Pic Quality
Discussion in 'Sky Digital TV Forum' started by petefletch, Dec 13, 2002.
  1. petefletch
    petefletch
    Now that Freeview has supposed to have increased it's picture quality, is it any better than Sky's Digibox?
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    I can't comment on Sky, but BBC & ITV channels on freeview look the same as on ntl cable TV.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    I've never seen a Sky system looking as good as DTTV on my IDTV
  4. petefletch
    petefletch
    Thanks Martin for reply. I have just bought a FQ-80 and am very disappointed with the quality of Sky and Telewest pictures. Lots of artifacts on moving objects. Terestial is fine , it's not the TV!
    Will have to consider swapping to an IDTV
  5. Squirrel God
    Squirrel God
    Or just buy a Freeview box :)
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    SQ will recommend the Pace DTVA
  7. Squirrel God
    Squirrel God
    Yeah, they are great.
    Did you notice how the last software upgrade added timer capabilities? :)
    Don't think you can get the DTVA anymore though can you? Not many outlets seem to be stocking it anyway.
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Mine is used on the bedroom TV
  9. petefletch
    petefletch
    Thanks for all the replies, would the consensus be then to get a freeview box? In the worst case scenario if its not any better than my Panasonic, Telewest boxes I can use it in the bedroom.
    The other option I guess is to swap my FQ80 for a NX200, but not sure why an IDTV should have better elecronics than an external decoder.
    I rang Sky and the guy stated that their transmissions aren't geared up for 100Hz TV's! Not impresssed! I didn't expect them to be broadcasting like "RealPlayer"56K !
  10. Squirrel God
    Squirrel God
    Yes, for most 100Hz TVs the source feed has to be good to reduce the risk of artefacts. Some Sky transmissions are good though.
  11. brichards
    brichards
    Jun 7, 2002
    +16
    :cool:
    Yes it is. I have Sky and a freeview Thomson Box.
    It is brilliant.
    Tried the Nokia Mediamaster but would not work.
    The Thomson is a different Beast!!!!!!!!!!!!!!!!:cool: :) :p :D
