Freeview Upgrade
Discussion in 'Freeview & YouView' started by daveb975, Jan 1, 2004.
  1. daveb975
    daveb975
    Oct 25, 2002
    4,248
    103
    London
    +347
    Having just bought a plasma, I have brought an old Philips ONDigital box out of retirement to feed it with a TV signal.
    Connected via SCART, the quality is acceptable, although I am experiencing quite a lot of signal break up.
    I have read on the forum about the relative merits of each of the current batch of Freeview boxes, but would these offer a significant PQ advantage over the old Philips?
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,038
    +2,980
    Signal break up is usually the sign of a insufficient signal from the aerial.
  3. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,709
    2
    48
    +62
    You would be better off with a new box and aerial.
  4. jakefraser
    jakefraser
    Although I will probably be told otherwise, the advantages of getting a brand new wideband UHF aerial and new cable to your DVB reciever are underestimated. These aerials do not cost as much as some people may suggest, and normally, breakup is due to the aerial feed quality.
    I am not aware that the picture on the old ONdigital boxes is any worse/better than the new boxes that are out, although the aerial signal processing is better (i think!?!) on the newer boxes.
    Jake.
    Happy New Year!
  5. nwgarratt
    nwgarratt
    May 5, 2002
    27,038
    +2,980
    Regardless what the freeview ad saids. Normally, you cannot just plug a box in at get it working straight away. This usually happens when you have a aerial that is years old and cannot pick up the digital signal.
    I had to upgrade my aerial for just £15 from a DIY store. My aerial was't that old (three years odl) but it wasn't good enough
    Also, my mum got a Philips ex ITV digital box and also had to upgrade the aerial. Her one was about 10 years old. The picture quality of the box on her TV looks exceptional and it is just a composite signal.
    The wideband high gain aerials have lots of elements sticking out as well as a mesh thing on the back. These can help to increase the signal strength.
    This is a similar aerial to the one I got.
    http://www.argos.co.uk/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=1001&productId=60916
  6. rudelad
    rudelad
    Slightly of subject what is the EPG like on the new boxes is it anything like SKY's. And I am right in saying I can't use this feature on my Pioneer Ondigi box?
  7. nwgarratt
    nwgarratt
    May 5, 2002
    27,038
    +2,980
    At the moment, the EPG just shows what is on at that time and what is on next. This works for all channels.
    From sometime early next year there will be a 7 day EPG. This should be like a whole weeks TV listing. Many new boxes are 7 day ready. My new Panasonic TUCT30 is ready.
    However, old boxes won't get the 7 day EPG unless a upgrade is available over the air. I don't think old ex ITV digital boxes will be one of them.
    How the EPG looks, depends on the box. The Pansonic looks very bland, but the Sagem 602 box is very nice. I don't know what the Sky one looks like.
  8. supersonic87
    supersonic87
    Dec 31, 2003
    286
    Swansea, Wales
    If you are having a constant signal breakup, try a setpal box (daewoo, novapal, etc), as these will help reduce breakup because of higher quality tuner, or if you want to go a bit higher up, try a netgem I-player (excellent tuner, broadband internet access, stream mp3s from pc, etc)
    Rich
  9. daveb975
    daveb975
    Oct 25, 2002
    4,248
    103
    London
    +347
    Thanks Guys - I think I will try the aerial upgrade.
    Does anyone know if the old ONdigital boxes can output RGB through SCART - I can't find a menu option on it.
  10. nwgarratt
    nwgarratt
    May 5, 2002
    27,038
    +2,980
    My old Philips OnDigital box can.
  11. bob1
    bob1
    Nov 7, 2002
    4,328
    Sheffield
    +131
    you might also need better cable
  12. daveb975
    daveb975
    Oct 25, 2002
    4,248
    103
    London
    +347
    I have got an RGB SCART cable. Would upgrading the RF lead to double shielded satellite cable make any difference without upgrading the cable from the aerial down to the wall socket?
  13. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,709
    2
    48
    +62
    I would say only if it's in very poor condition,though it would be advisable.The biggest difference would be getting the next gain aerial up from the one you have now.What element aerial have you got now?
