Freeview UHF indoor antenna
Discussion in 'Freeview & YouView' started by subin, Jan 11, 2012.
  1. subin
    subin
    Jan 11, 2012
    15
    3
    I just brought a UHF indoor antenna its working really good everything works fine including the electronic program guide. The quality is really good on my 55 inch Samsung D7000 Led TV . Now the only thing i am wondering is if there are any hazards (radiation or something liek that because its UHF not VHF ) to using indoor antennas ( aprroximately the same size as the normal bunny ears ) .
    Thank you :)
  2. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +617
    Freeview aerials receive radio signals, they don't transmit anything !
  3. subin
    subin
    Jan 11, 2012
    15
    3
    so there will be no problems if it only receives ?
  4. JayCee
    JayCee
    Jan 20, 2004
    23,203
    Lanarkshire
    +2,483
    None whatsoever.
