Freeview tv in Spain? Help needed
Discussion in 'Freeview & YouView' started by muppetmick, May 14, 2004.
  1. muppetmick
    muppetmick
    Nov 11, 2002
    84
    over the rainbow-way up high!
    Hi everyone
    I was in Spain earlier this week and noticed in the hypermarket in Almerimar that they were selling Freeview boxes for 99 euros.On one side it had a list of certain Spanish channels and on the other side a complete list of the UK Freeview channels!
    Question is: Can I use one of my existing OnDigital boxes whilst in Spain and does anyone have any idea what channels I could pick up?
    Mick.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Most Ondigital boxes will work ok on other European DTTV (Digital Terrestrial TV) transmissions.
    Some older ones may not because the UK system uses 2048 carrier COFDM modulation whereas the full DVB-T standard uses 8192 carriers.
    The early UK boxes were the first out there and some earlier tuner chipsets could only handle 2048 carrires - they hadn't got around to making the early chips work at 8192 carriers.
    So YMMV if you have an older chipset in your OnD box.
    If you have its handbook, the specifications should tell you if it can handle full DVB-T at 8192 carriers.
    Chris Muriel, Manchester.
  3. muppetmick
    muppetmick
    Nov 11, 2002
    84
    Thanks for reply Chris.
    I have the following two models:
    Nokia 9850T
    Philips DTX 6370
    Will either of these be of any use in Spain?
    Thanks.
