We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Freeview to LCD TV
Discussion in 'Freeview & YouView' started by Kube, Oct 26, 2005.
  1. Kube
    Kube
    Mar 21, 2005
    5,387
    Armagh
    +370
    Anyone running Freeview through to a LCD TV. I was just wondering what connnection you use?
    Recently bought a freeview box and Dell 26" LCD and noticed that the Freeview outputs scart only while the tv doesnt have a scart connnector. Do i have to run composite in then?
    cheers lads
    K.
  2. JayCee
    JayCee
    Jan 20, 2004
    24,252
    Lanarkshire
    +2,669
    What other inputs does your LCD TV have?
    If only composite that's the only way to do it then I'm afraid.
  3. Kube
    Kube
    Mar 21, 2005
    5,387
    Armagh
    +370
    It has HDCP, PC monitor connector and and the rest are audio.
  4. Kube
    Kube
    Mar 21, 2005
    5,387
    Armagh
    +370
    Guys, just found that the TV has a s-video and component input. (hidden under a flap at the back) Is this the best method for me? Any help is much appreciated by the way.
  5. JayCee
    JayCee
    Jan 20, 2004
    24,252
    Lanarkshire
    +2,669
    Yes, as long as your Freeview box outputs s-video.
  6. Kube
    Kube
    Mar 21, 2005
    5,387
    Armagh
    +370
    Just had a check and the box doesnt output s-video. Is that S Video and component ruled out then?
  7. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    Lets get back to basics,what outputs does your Freeview box have. ?
  8. Kube
    Kube
    Mar 21, 2005
    5,387
    Armagh
    +370
    Scart output on the rear and no mention of any signal output in the manual. Thomson Dti550.
  9. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    It seems to me that you aree a bit stuck if the tv does not have a SCART socket, but someone may know different. Dell tv's are intended for the non-European market. Hence no SCART.There are Freeview boxes that may provide the outputs you require. Try looking at the current Sony model.
  10. Kube
    Kube
    Mar 21, 2005
    5,387
    Armagh
    +370
    Will do, cheers mate.
  11. darrenjuggins
    darrenjuggins
    Dec 4, 2004
    95
    +8
    Basically you have two issues - Picture and sound.
    I'd suggest going to a good electrical shop (Not Comet, Dixon, etc) and asking for a Scart lead socket with S-VHS connetion on and also component outputs, They are not very expensive.
    This way you can connect to the LCD for Sound and vision.
    S-VHS Socket = Video only.
    Your Phono (Red & White, Normally) = Sound.
    Should be able to do it for less then £10 - Thats for Scart adaptor, S-VHS lead and a set of Phono leads.
    Happy shopping
    Darren J
  12. JayCee
    JayCee
    Jan 20, 2004
    24,252
    Lanarkshire
    +2,669
    Kube already stated his Freeview box doesn't output S-Video.:confused:
