Freeview to Benq projector via SCART anyone?
Discussion in 'Projectors, Screens & Video Processors' started by organica, Oct 25, 2005.
  1. organica
    organica
    My Dad has got himself a freeview box (Bush DFTA7) and I'm planning to get it hooked up to my projector (Benq PB6210). The Bush outputs on SCART only, however I believe it transmits an RGB signal via the SCART, and my projector accepts an RGB signal via its VGA input.
    Is this likely to be a goer? Or is the RGB input on the Benq (intended mainly for computers I presume) a different type of signal, and not going to work because of interlacing / sync / etc...?
    I know the Benq's VGA input is not a one-trick-pony, since it also understands a YPrPb signal from my DVD player, but perhaps this would be a step too far?
    Any suggestions / experience on this one?
  2. Bugblatter
    Bugblatter
    There was a thread about this a couple of months ago, someone posted a link to a cable that did the job. Hopefully a search will bring it up. If you get it working let me know, I might go the same route :)
  3. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    I have used my H30 with my Sky box using the vga/scart adapter and worked great, only problem i had was that the video would go in and out of sync in a subtle almost unnoticable way and would only effect certain parts of the image. Also audio sync was a problem on some sky channels.
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,237
    Scotland
    +189
    As far as I know the BenQ won't accept RGB scart type signals. Only computer RGB. I've tried making up a cable for my PB6100 with no joy whatsoever.
    In the end I went to maplin and got a scart RGB to s-video convertor which worked well enough.
  5. organica
    organica
    Thanks for the replies folks.
    I also submitted a support request to Benq about this, but no joy as yet.
    Had a look at the Maplin converter box.
    £35 - but also removes "degrading copy-protection artefacts" :D
    If I have any response from Benq I'll post back, but going on the basis that cyberheater is the sort of guy to experiment with various pin combinations, I guess it doesn't look too promising.
    I had intended to steer my Dad in the direction of the Netgem or something, but he ended up impulse-buying in Aldi!
  6. cyberheater
    cyberheater
    Apr 3, 2003
    3,237
    Scotland
    +189
    Looking forward to seeing if BenQ replies. I spent a fruitless night making up various leads and I could not get it to work. Only component and computer VGA.
  7. Bugblatter
    Bugblatter
    My DVD recorder (Panny DMR-E500H) takes a scart input and outputs both scart RGB and component. It seems to do a reasonable job of converting it.
    I'd like to also have a direct connection between the ntl box and the BenQ PE7700 though
  8. organica
    organica
    Still no reply except for a confusing automated one directing me back to the place I had posted the query.
    We shall see...
