FREEVIEW - Sudden Lose Of ITV1/2/3 & Channel 4/E4/E4+1
Discussion in 'Freeview & YouView' started by Andy Davis, Aug 3, 2005.
  1. Andy Davis
    Andy Davis
    I've had my IDTV working fine since new at the end of June, yet suddenly all ITV and Ch4 services have a 'no signal' message. All other channels working fine, as well as interactive services.
    I've re-aligned the aerial & re-installed to try and fix this but no luck. I would guess that this is a transmitter stopping broadcasting as it seems to cover all those channels. This happened sometime over last weekend.
    Can anyone help please, I live in postcode area LD3 at the western end of the Brecon Beacons.
  2. Andy Davis
    Andy Davis
    Problem sorted :oops: .
    I feel so stupid. After reading the other thread about a similar problem I had a rethink. I have a booster with 3 different levels of boost. when I had set up the tv I hadn't used a booster and although it found the above channels, it wouldn't display them, so a while later i plugged in the booster and I had reception :) . I must have plugged the aerial into the wrong boost over the weekend whilst rearranging the wires and ended up with nowt.........tut tut......
