Freeview/Sky Digital- can I Improve signal?
Discussion in 'Sky Digital TV Forum' started by andyxxx, Jan 5, 2005.
  1. andyxxx
    andyxxx
    Nov 12, 2002
    115
    16
    Since purchasing a larger set I am noticing more blurry pictures sometimes with silvery shadows and inadequate details - this is both through sky digital or alternatively through a Sony digital freeview receiver. (I never see the picture break up/blocking)
    My question is this. Can the picture be improved on either of these methods of receiving - by for example resiting the dish?
    I have just been told by the aerial engineer who installed the digital aerial for the freeview that this is not possible.
    This sounds odd to me?
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi Andy
    it sounds like it might be some inbuilt video processing in your new TV set (assuming it is a CRT). Try switching off these features as they often make the picture worse.
    good luck
  3. andyxxx
    andyxxx
    Nov 12, 2002
    115
    16
    David
    No it is a DLP (that I am also having major lip sync problems with) I can't see any options to be able to alter video processing (If DLP even has it)
  4. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi Andy
    if you let us know the make/model we will take a look..
    cheers
  5. andyxxx
    andyxxx
    Nov 12, 2002
    115
    16
    Thank you David
    It is an Optoma RD50
    regards
    Andy
