me9141
Hi all,
Hope you are well.
Have used freeview in the bedroom for over the last 10 years. its always worked fine with good signal and all channels. I use an internal areial and have wired this to sit at the top of the wardrobe.
Two weeks ago the signal has just gone absolutley un watchable, with the generic pausing and jumping due to signal on most channels.
Nothing else has changed in terms of cable, areial position or t.v. Have checked freeview's website, it says the signal is normal in our area. I do not use an ampliphier, the areial is plugged straight into the t.v using an extention.
Was wonderieng if anyone else has had the same experience.
Any help is greatly apprecited.
Thanks in advance.
Kind regards,
Sam
Hope you are well.
Thanks in advance.
Kind regards,
Sam
