Freeview requirements
Discussion in 'Freeview & YouView' started by Wizzard, Apr 22, 2005.
  1. Wizzard
    Wizzard
    Feb 27, 2005
    82
    Can one get freeview reception using a portable ariel above the TV or does one need a special ariel? I get very good analogue pictures on the other TV using a loft ariel.
  2. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
    Yep, if the signal is strong enough in your area then you can get digital from a set top aerial.
    Most people do need a high gain aerial outside or in the loft.
