Freeview reception
Discussion in 'Freeview & YouView' started by Smalltime, Apr 21, 2005.
  1. Smalltime
    Smalltime
    I recently ditched Sky and bought a Freeview box (Sony VTX-D800U), it was great for the first 3 weeks. Great reception, crystal clear picture etc. But suddenly the reception has become awful and getting worse. I've started losing channels left right and centre and now only get a handful (mostly the BBC channels, but no Channel 4, 5 or ITV at all). Why would this be when it was fine for weeks and has now been like this for over a week (I'd accept it if it was for a day or 2). Is there anything can be done about this as I assumed I was in a decent area for Freeview after getting the good reception or do I just have to cut my losses and go back to Sky? Would rather not really!
  2. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    What signal strength and quality is the Sony reporting for the various channels? The BBC channels are transmitted using a more robust encoding; ITV's and Channel Four's are more susceptible to interference and noise.
    It may be that the weather is to blame (wet, leaky co-ax, for example). How's your analogue reception at the moment?
    Of course, it is also possible that you have a faulty receiver.
  3. Smalltime
    Smalltime
    My analogue's fine and my signal strength and quality are both Average on BBC 1 which is the best quality of anything even though right ow it is breaking up all over Neighbours. The weather has been a bit all over the place (Manchester) but it's a peach of a day today, though still quite cold, so dunno if it can be that. If the receiver is faulty, why would it have been fine for 3 weeks with nothing being done that could 'break' it?
  4. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    Well, electronics can just develop faults spontaneously. Perhaps a component is enduring a long, drawn out death. :)
    I do think it's more likely that your signal is the problem tho'. But if that was fine for 3 weeks too... something must have changed. Any chance of trying a signal booster? Could your aerial have moved? Is it an outdoor, loft or indoor aerial?
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,684
    Galactica C.I.C.
    +214
    Have you checked to see if any damage has been incured to the arieal? HIgh wind,birds sitting on it ect?
  6. matty2767
    matty2767
    has your aerial cable from the wall to the box slipped near the power cables. before i got a shielded one if the cable went near the power cable the picture went off. must have been due to interference.
  7. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
    Try borrowing a freeview receiver to test it out.
  8. Tocsin
    Tocsin
    Mar 4, 2005
    35
    Off the wall idea - are there trees/bushes in line of sight of the aerial? Its Spring, and leaf growth can make a difference!
  9. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
    Good suggestion.
