Freeview radio & DAB?
Discussion in 'Music Streamers' started by malsat, Aug 18, 2005.
  1. malsat
    malsat
    Sep 13, 2004
    291
    +10
    are they the same or is there a difference?
    thanks,
  2. kbfern
    kbfern
    Aug 17, 2002
    17,781
    Wolverhampton
    +5,950
    A dab radio will get you more channels including local channels you would not get with freeview.
    Also you do not need your tv on to see what channels you are getting/listening to.Also dab gives additional scrolling info such as tracks playing and other info.
  3. roversd1
    roversd1
    The encoding is different at the transmission end (before it reaches us).
    Freeview tends to sound worse than DAB.
    Best ask 'GrahamMG'
  4. malsat
    malsat
    Sep 13, 2004
    291
    +10
    thanks
  5. Dean
    Dean
    Jun 20, 2003
    2,887
    London
    +263
    Actually thats incorrect. DAB and Freeview use the same MPEG1/2 Layer 2 codec and Freeview has better bit rates hence better sound than DAB. I would avoid getting a DAB due to the low bit rates in the UK.. see :eek: http://www.digitalradiotech.co.uk/digital_radio_samples.htm
  6. ad47uk
    ad47uk
    Apr 21, 2005
    749
    +6
    Correct 100%.
