Freeview problem? is it the box?
Discussion in 'Freeview & YouView' started by Hobbess253, Oct 17, 2004.
  1. Hobbess253
    Hobbess253
    I just got a new Sony KF42sx300 TV and had bought the Sagem ITD64 box a week or so previous in preperation.
    For the whole week before i got the Sony, the box was running fine with no reception problems on any channels. I then moved the new TV in and connected everything up. Xbox, DVD player all working a treat but the digital reception is now causing grief!
    At the moment the problem is with ITV 1+2, channel 4 and some others. all the BBC's are fine. They are really blocky and keep breaking up or dissapearing. I am pretty sure the connections are all good as Menus from the box all display fine. The box is telling me that the bad channels generally have a signal strength of over 50% and quality of over 90%
    I have changed scarts, played with settings, borrowed an aerial booster and am now fresh from having the Aerial wall socket off to play with as I had thought I had narrowed the problem down to it being a dodgy connection there but that wasn't working. I have now moved the box to another room to try and the problem is the same there so the socket is probably not the issue.
    I am probably going to take the box back to comet tomorrow but I am confused as to why it was working and now isn't. Is there anything else I can try?
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    A lot of people seem to be getting ITV problems at the moment - however try a different box just to be sure
  3. mxdshf
    mxdshf
    Mar 21, 2006
    56
    +3
    Your signal is poor. It should be 65%
  4. jetinder
    jetinder
    Sep 16, 2006
    1,594
    63
    +139
    Get a signal booster to boost the signal of it.
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,752
    Somewhere in South Yorkshire
    +4,906
    New answers to a very OLD thread !
  6. greycounciller
    greycounciller
    Mar 14, 2006
    431
    28
    London, NW
    +26
