Question Freeview Play disappeared
Discussion in 'Hisense TVs Forum' started by dvds2000, Jul 21, 2018.
  1. dvds2000
    dvds2000
    Aug 3, 2009
    4
    Hi all, I've got a 43" Hisense, not sure of the model but is running V00.01.00a.H1229
    Sometime over the past few days Freeview Play has totally disappeared, no menu item or anything, but if I go into the EPG it does show the Freeview Play logo in the top left corner. However, going back on the EPG just says no catch up programme on all channels.
    Don't suppose anyone has seen it before and knows of a fix? Thanks :)
  2. JayCee
    JayCee
    Jan 20, 2004
    23,993
    Lanarkshire
    +2,615
    Tried rebooting as in pulling the power plug then plugging in again?
  3. dvds2000
    dvds2000
    Aug 3, 2009
    4
    yeah tried that a couple of days ago, then did it overnight but made no difference :(
    I haven't tried a factory reset yet as don't want to lose my settings, but thought I would see if it had happened to anyone else before I did it. I've emailed Hisense so will see what they say too :) Thanks for your reply.
  4. Jaz284
    Jaz284
    Jul 22, 2018
    2
    4
    London
    Glad i’m not the only one! Just noticed its happened to me too! I’ve done a factory reset but still not seeing the Freeview Play menu. I see the logo in the EPG menu (same as you) but nothing else. Hope it gets fixed!
  5. dvds2000
    dvds2000
    Aug 3, 2009
    4
    Well although its not good its happened I'm relieved it's not just me as it means the TV is unlikely to have a fault! If I get a reply from Hisense I will pop a post on here :)
  6. Jaz284
    Jaz284
    Jul 22, 2018
    2
    4
    London
    Hi dvds2000,
    I managed to get Freeview Play back - I contacted the Hisense Support Team and they gave me a file to upgrade my tv software with. Just tested 4od and working as before :clap:
    I can DM you the link if you like but not sure if it's for your model? (mines is H50M3300)
    Hope yours gets sorted also! :thumbsup:
  7. dvds2000
    dvds2000
    Aug 3, 2009
    4
    Thanks for that, I got an over the air update a couple of days ago that fixed it. Still waiting for a response from Hisense though!
    Glad you got yours sorted :)
