Freeview..Just got a box! Minor problem
Discussion in 'Freeview & YouView' started by gam3r, Mar 22, 2006.
  1. gam3r
    gam3r
    Mar 22, 2006
    261
    London
    +4
    Hi there, First post :D
    Being within the line of sign to the crystal palace communications tower, and being on a hill i decided to bite the bullet and go for a freeview box. I got your bog standard bush dfta3 - im happy with it so far:clap:
    Now here is the deal. Im using the box in my room, through a indoor aerial that came with my TV and i pick up all the channels. But the thing is when i try watching these channels:
    - E4
    -More4
    -BBC1
    -BBC2
    -ITV 1, 2,3,4
    -Channel 4
    The signal quality is 0 and i get no picture. I think this is probably due to me using a standard indoor tv aerial. To correct this, im going to buy a proper amplified aerial from maplins, which should be ok as i live close to crystal palace.
    Now here is the funny thing.
    I can view E4+1, more4+1 and BBC 3 with no problem at all, signal quality 10/10.
    Weird huh? Why?
    Thank you!
  2. JayCee
    JayCee
    Jan 20, 2004
    23,754
    Lanarkshire
    +2,568
    It's all down to poor reception on certain "Multiplexes"...have a look at http://www.dtg.org.uk/retailer/dtt_channels.html and you will see which multiplex each programme uses...you could probably do with a good outside aerial to be sure of good reception.
  3. gam3r
    gam3r
    Mar 22, 2006
    261
    London
    +4
    Outside aerial is not a option really..Thanks for the reply :)
  4. Andy3
    Andy3
    Jun 20, 2005
    634
    Cheshire
    +19
    gam3r, try moving the aerial around from side to side and back and forward. Just a few inches can often do the trick.
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Reception close to Crystal Palace can be a problem, because CP uses three transmitting aerials, and in some places the signals can cancel each other. In areas close to the mast you will see lots of very small aerials on quite tall poles. Moving the aerial slightly might help, as others have suggested.
  6. gam3r
    gam3r
    Mar 22, 2006
    261
    London
    +4
    Sorry i made an error in the first post, i can pick up BBC1 and BBC2 and at nightime i can pick up more4 and e4 with a signal strenght of 1. Looks like a better aerial specialised for freeview(seen a good one at maplins) may do the trick.
    Moving around the aerial doesn't do much for me :(
    Thanks for all the replies people!
  7. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
  8. RobbySpurs
    RobbySpurs
    Feb 23, 2004
    4,727
    London
    +2,867
    Slightly on topic and slightly off topic - do some freeview boxes pick up a strong signal better than others? I have a Tosh 20WLT56 with built in freeview and that works brilliantly, and yet my Philips DTR320 keeps blocking and "schneeking".
  9. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    They will vary in terms of both sensitivity and overload performance (IP3 etc. for the RF technically aware) from model to model, depending on the tuner design - especially the front end amplifier and 1st mixer.
    Chris Muriel, Manchester
  10. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    Yes, definitely. Some receivers are rather "deaf" - which is great if you are near the transmitter - and some are very sensitive - which causes big problems if you are near the transmitter. Some people have to fit an attenuator. The choice of cable and aerial is also important. There's an eBook called "The Freeview Bible" which goes into this in detail.
