freeview help
Discussion in 'Freeview & YouView' started by nuker, Sep 16, 2004.
  1. nuker
    nuker
    Sep 11, 2004
    24
    4
    :lease: thinking of trying one of those indoor aerials in bedroom to see if i can get freeview, live in coventry says signal is ok. anyone got any ideas how successful it would be.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Have you tried the postcode checker on the Freeview website?
    If you get good coverage then a wideband indoor aerial may work but impossible to say because it may depend upon exactly where in your home the TV is:)
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,384
    Somewhere in South Yorkshire
    +5,770
    Propagation of radio waves, especially through solid objects (like walls) is highly unpredictable.
    In-room aerials suffer from two things - the walls of the premises it is in, and the walls of other buildings in the signal path. Typically a rooftop aerial will have a clear "view" over nearby buildings towards the transmitter.
    A good few years ago, I was billeted in a house in Thorne, South Yorks. By a huge margin, the nearest transmitter is Belmont in Lincs. However, I could only get a clean signal from all (4 at the time) channels by using the much more distant Bilsdale transmitter - nominally far too distant for satisfactory use, expecially with an indoor aerial. Just illustrating how unpredictable reception can be, from indoors.
    You can but try it.
