freeview hd signal strange problem
Discussion in 'Freeview & YouView' started by extra330, Feb 26, 2013.
  1. extra330
    extra330
    Jun 16, 2010
    12
    I have a sharp 60" led tv with built in tuner, running through a panasonic freeview hd recorder.
    This set up has been fine for the last 6 mths, until a fortnight ago
    when tv is first turned on there is no hd channels available and no signal message appears.
    if i leave it on a hd channel it comes on after approx 15 mins, pixelated and broken up picture for 5 mins and then it is ok
    I had a new aerial 6mths ago so dont think its that
    i am on the lancaster transmitter whom reports no faults.
    does this sound like my tv or my aerial
    thanks in advance
  2. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Test the TV with a different signal source.
    Sounds like faulty capacitors warming up, to me.
  3. extra330
    extra330
    Jun 16, 2010
    12
    excuse my ignorance.
    what do you mean Martin ? different signal source? do you mean try another aerial, or are you saying a capasitor within the tv if so how do i do that
    cheers
  4. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Test the TV with another signal source, such as a DVD player.
    It might be a faulty component in the TV or in something else (e.g. Panasonic Freeview recorder) or an aerial amplifier (if fitted). But no point in guessing. Test everything.
