Freeview HD reception problems.
Discussion in 'General TV Discussions Forum' started by nmp, Oct 26, 2018.
  1. nmp
    nmp
    Jan 16, 2006
    134
    16
    I have an ariel in the loft pointing to Crystal Palace. In the five years since it was fitted, reception has been fine. In the past year, I have had intermittent problems with HD channels at times completely losing all channels on Mux PSB3. I also am unable to receive channels at all on COM7.
    I had a low loss splitter, but have removed that temporarily but the problem persists. Is my ariel no longer fit for purpose or could it be something else glaring that I am missing?
    As I say, this was a new ariel fitted in 2013, and worked fine until about a year ago. Now intermittent problems with typically the HD channels. SD seems fine.
    Any pointers much appreciated.
    thx
  2. nmp
    nmp
    Jan 16, 2006
    134
    16
    Well after the overwhelming advice received, I decided to get in an ariel fitter. He tested the signal and confirmed it was good. After checking everything else he concluded the problem was with tree's in a neighbouring garden that have grown in the past few years to a height that could be now intermittently be affecting the signal and advised I either move the ariel up to the Chimney outside, or fit a masthead booster. I opted for a powered masthead booster and this has resolved my problems.
    Hopefully helps someone in the future.
  3. nmp
    nmp
    Jan 16, 2006
    134
    16
    Also, to add, I also was advised to investigate 4G Cell tower interference. I contacted https://at800.tv/ who confirmed there were active 4G cell towers in my vicinity and provided a 4G filter at no cost. I cannot be certain whether this or the amplifier resolved my issues, but the combination of the two have helped.
