Freeview hardware con?
Discussion in 'Freeview & YouView' started by thebigkung, Jul 28, 2005.
  1. thebigkung
    thebigkung
    Hi Peeps,
    Except for external connections, are there any differences between the freeview boxes?
    I have see 4 in Currys which were completly different priceses with different branding names on them but they were Idential in every other respect. The same size, the same ports. The led lights and heat vents in the same positions.
    They ranged from £60 to £90. Are you getting any more for your money with the higher priced items?
    Best Regards,
    Len
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Better quality build ?
  3. thebigkung
    thebigkung
    Nope :smashin:. These 4 seems to be from exactly the same factory but with different brand names and fronts.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Every manufacturer regardless of if a product is built in house or contracted out has their own specific overheads and what sort of profit margin to include, sometimes simply based on their position in the market and what they consider the brand name is worth to the consumer.
    It's not uncommon to pay X amount for a product when exactly the same item differently packaged is cheaper but still thanks to the lack of a well known "name" does not sell as well.
  5. thebigkung
    thebigkung
    Thank's, I understand that, but is there any functionality difference between the boxes? Is the software or firmware better from one box or the next or is the electronic program delivery and digital text stuff all the same?
    Best Regards,
    Len
  6. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,109
    Manchester
    +713
    They will mostly be based on reference designs of which only a couple were produced.
    The manufacturer pays for the IP and then can choose how much he may want to modify it as well as for any software and user-interface hooks he wants to include.
    Google for "Setpal" and/or "Novapal" to get more background on the reference designs.
    Chris Muriel, Manchester, UK
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the quality of components may vary as may the software doesnt mean the more expensive one will have better software tho......
  8. rhubarbe
    rhubarbe
    May 25, 2005
    4,668
    Cheshire
    +211
    I think that you are oversimplifying this. There is now becoming quite a number of these devices, the later ones with dual tuners and large 160Gb hard drives.
    I have a TF5800PVR and wouldn't be without it. Neither will i hear anything said aginst it ;)
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the original post refers to a specific set of basic DVB-T decoders not the availability of different boxes with different features HDD based PVT FV tuners have been around for a couple of years at least now
  10. thebigkung
    thebigkung
    Thanks peeps for the replies.
    Yes, All I want to know is if 'Freeview' and how it works and the information and setup differs from set-top-box to set-top-box, like if you buy a sky box the 'basic' functionality is the same across all the manufactures.
    Regards,
    Len
  11. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Performance, build quality and functionality will differ from box to box even from the same manufacturer or based on a common design sourced by many companies.
    Apart from the basic design of the tuner to access UK DTT signals and the MHEG support there is no real "standard" for DTT (Freeview) boxes which is one of the reasons a million or so boxes will never get a real EPG or lack other things such as a RF modulator, digital audio output, component output etc etc but on the up side there is a rapid product cycle as manufacturers compete for market share.
    Right now there should not be a Freeview box for sale that doesn't support the 7 day EPG which is about the only standard feature that could be market lead everything else is pretty much left to the manufacturer.
  12. thebigkung
    thebigkung
    Thanks :smashin:
