Freeview Freeze
Discussion in 'Freeview & YouView' started by rosemanbridge, Oct 23, 2003.
  1. rosemanbridge
    rosemanbridge
    May 24, 2002
    257
    My Nokia 221 which I installed last week keeps freezing the picture. I exchanged it for a new one, but it is still freezing. Channel 4 and The Hits channels are also very pixellated and sound is choppy. Is it a fault with the box? I am in Worcester area and tuned to the Malvern transmitter. Thanks.
  2. bobones
    bobones
    Jan 15, 2002
    453
    +7
    The Nokia is prone to freezing when the picture breaks up, but the break up is probably caused by poor reception in the first place.
    I've had a 221 since January and while I quite like a lot about it, there are better boxes around now with fewer bugs. If I were you, I'd exchange the Nokia for a Pioneer or Sony box and get your aerial seen to by a professional if you're still getting reception problems.
  3. loz1
    loz1
    Dec 11, 2002
    84
    Edinburgh
    Yeah my 221T is the same. Doesn't happen often but when it does I have to switch it off at the mains. Seems particularly bad when using teletext.
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,184
    +3,037
    I have a new Philips 1500.
    I keep getting CH 4 and ITV channels breaking up. I can only think it is down to reception and the aerial.
    It has been doing it in the evening and usually when I start recording.
    The weird thing, I have a IDTV and using the same aerial cable, the picture is fine.
    The only thing left is too mess around with the aerial.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Get CAS back to check the signal strength
  6. rosemanbridge
    rosemanbridge
    May 24, 2002
    257
    CAS are coming in the week to check signal strength. I swapped the Nokia for the Pioneer as it had an optical out socket. It doesn't freeze up, but the picture is still breaking up. The strength on the box is averaging 91% so I don't know if CAS can do anything???
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Are you pointing over a main road (eg A449)?
    If so maybe tilting aerial up at 5% may help.
    Are any channels worse than others?
