Freeview Dolby Digital (?)
Discussion in 'Freeview & YouView' started by figrin_dan, Nov 1, 2004.
  1. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,057
    +166
    I know I shouldn't listen to what they say on QVC but the guy was quite adamant that DD will be coming to Freeview in just a few months. This would explain why there are quite a few boxes with the logo on the front.
    I thought freeview didn't have the bandwidth, or are they going to change the signal again?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    There is no technical reason why DD can't be used on Freeview.
    There are economic and practical reasons it hasn't been:)
    A broadcaster has to license the technology which probably ain't that cheap (The BBC are resistent to paying for some technology). There is a limited amount of bandwidth, an additional 384kbs per channel is significant on DTT and for many channels just a waste of money, lets face it picture quality isn't high on the agenda for many broadcasters so why should audio quality.
    There is also the percentage of Freeview boxes that have either optical or coaxial audio connections to feed a suitable amp or tv, has to be a factor in a decision to use the format by a broadcaster.
    I would be surprised if DD audio appeared any time soon but I thought the same about PAY tv on DTT turning up before analogue shut down:)
  3. BazMan
    BazMan
    Nov 2, 2004
    609
    Northampton
    +24
    You know the bit in the rules which tells us to check threads before posting a new query, in case it's already there? Well, I'm glad I did.
    I have a Pioneer DTR (DBR-TF100) with an optical link to a Sony STR-DE495P and must admit I was fooled by the Dolby Digital badge on the DTR; Really thought I might have set things up wrong, as I am only getting DPL.
    Now I know. Shame really. :rolleyes:
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,552
    Somewhere in South Yorkshire
    +6,052
    Isn't it true that Freeview sound is already carried using DD - but only in 2 channels - like many DVDs of early films?
  5. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,057
    +166
    According to the Phillips manual, it's MPEG 1 sound.
  6. Family Guy
    Family Guy
    If it was DD, it would light up the DD light on my 3805, and also if it was DD stereo, two speaker lights would also light up indicating DD stereo...this dosen't happen.
  7. Kevo
    Kevo
    Aug 23, 2001
    5,415
    Manchester
    +151
    No, it's defo mpeg audio. Which is not even as good as good old analogue NICAM.
    Also, don't rule out DTS. They expressed an interest in european digital terrestrial broadcasts not so long ago. Although I've never seen a stb that has dts encoding.
  8. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    DTS is now part of the offical Digital broadcasting spec but if a channels capacity is too tight as to make DD a non-starter then DTS is a definite no no:)
    Couple that with DD being the format pushed for High Def audio by the EBU and the norm for US and other nations HD services you can see that DTS would have a long way to go. HD-DVD and/or Bluray might be an option but lossless audio formats are envisioned for those platforms which makes both DD and DTS outdated but no doubt both have variants that could be used in the future.
  9. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    DD 5.1 would fit - only twice he band width of a radio channel
  10. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    Freeview (and indeed all DTV products in Europe), use the MUSICAM system for audio which I believe is based on MPeg1 audio.
  11. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    It's not a question of it fitting, it's the need for a broadcaster to allocate bandwidth from either it's other TV or Radio channels or buy additional capacity on other muxes(not practical for the likes of the BBC) and certianly not economical when subscription services would have inflated the price. DTT has limited capacity (Until analogue switch off and ditching mpegII) which is not going to be thrown away on DD audio.
  12. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,484
    64
    Norfolk
    +228
    No, the capacity is thrown away on crud channels instead.
  13. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Crud channels that can afford to pay the carriage costs which makes you wonder why existing "quality" broadcasters can not do the same to improve both video and audio quality.
