Freeview Digital TV PCI Card
Discussion in 'Freeview & YouView' started by Dharans69, Apr 16, 2005.
  1. Dharans69
    Dharans69
    Is it possible to get all the channels on Freeview Digital TV PCI Card. Or would you require a PCI Card with a card slot (If one exists).
    I have a Sony Freeview Digital Box, which doesn't have a card reader, but would also like Freeview on the PC, just wondering if the all the channels are available, if not is it possible to get additional software that allows all the channels :devil:
    Baz
  2. Andy_Lee
    Andy_Lee
    Mar 12, 2005
    98
    Telford Shropshire
    Hi Mate
    I've not seen a Freeview card for a PC yet with a card slot. I have USB freeview tuner which certainly does not. I know of Satalitte cards which have CAM slots but not terrestial stuff.
  3. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    I have never used a PC TV tuner and know little of the manufacturer but I did find this recently. I don't think it's designed for the UK (no support for MHEG, for example) but it does support CAMs. Any use?
