Freeview Digi Box Problem
Discussion in 'Freeview & YouView' started by Plasmajoe, Jun 4, 2005.
  1. Plasmajoe
    Plasmajoe
    Hello,
    I have 2 Bush freeview digi boxes, one up stairs one down but both seem to lose the channels from time to time even though i can view the channel and signal strengh indicator but no picture, also on occasions when this happens i cannot view the channels unless i go past to the next channel then return back to the channel i wish to watch, each time this happens i have to keep reinstalling then everything is fine again for a while. On the odd occasion they trip out and the green light go off and the red light comes on. Is this a signal problem or a problem with the digi box itself?
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    It sounds like a problem with the box. A correctly working box would tell you in the way of an error message if there was a signal problem. If the green light's going out, it's a hardware problem.
