Freeview Desktop Box - With Vga Output?
Discussion in 'Freeview & YouView' started by Noodleman, Mar 18, 2006.
  1. Noodleman
    Noodleman
    Jan 6, 2006
    49
    Hello,
    does anybody know of any freeview box's that allow you to output using VGA, instead of scart/svideo etc...
    want to use it on my projector, and use the VGA to get the higher quality image.
    Thanks.
  2. pigbite
    pigbite
    Oct 3, 2005
    38
    +3
    I don't know of a box with VGA outputs and I'm not sure of what the implications of different resolutions etc would be anyway.
    What you might consider is using an RGB to component convertor like the QED one. If you projector takes component (and most do) then this does result in a apparently better quality quality signal. Bear in mind that the signal is not being improved, just converted however in my experience the results are excellent and well worth it. I have used them in home cinema installations with Sky+ and been very pleased at the smoother image quality at large projection sizes.
    The kit is about £100.
    Jez
  3. Noodleman
    Noodleman
    Jan 6, 2006
    49
    Ah,
    Thanks for the info. I will do some reading into that :)
    appreciate the reply.
  4. the whistler
    the whistler
    Feb 22, 2006
    702
    43
    +133
    I'm sure ZINWELL used to do one, but i can't find any details of it on the web
