Freeview Channel 5
Discussion in 'Freeview & YouView' started by omar, Mar 6, 2003.
  1. omar
    omar
    Friend has just got Panasonic freeview box, is it normal to have a problem with channel 5 reception.
    All other channels seem ok is there a cure, RF is switched off
    Any ideas thanks
  2. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    You shouldn't really get problems with Five, it may be that the multiplex it is broadcast on isn't received as well as the others in your area. Have you checked the aerial positioning / suitability for digital reception?
  3. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    I have no problem with my panasonic on 5 even though the analogue 5 reception is unwatchable
