Freeview box without Scart!
Discussion in 'Freeview & YouView' started by WBC, Jul 5, 2005.
  1. WBC
    WBC
    Guys,
    Can you recommend me a freeview box that doesn't require scart that I can connect via RF into the TV??
    I am currently using a pacific and don't seem to be able to just use the RF?!!
    Naturally the cheaper the better, it is only for a second TV in the Bedroom
    Stace
  2. 9761
    9761
    May 16, 2005
    499
  3. WBC
    WBC
    Thanks.
    Do you know of any freeview brands that offer this?
    I don't really want an extra box in the bedroom.
    Thanks Again
    Stace
  4. 9761
    9761
    May 16, 2005
    499
    Whats your price range?
    Usally the more expensive freeview boxes have RF modulators where as the cheapish ones only have RF loopthrough.
  5. WBC
    WBC
    I want to spend as little as possible but will extend if it gives me the functionality.
  6. 9761
    9761
    May 16, 2005
    499
  7. WBC
    WBC
    More than I wanted to spend......but that'll do me!! ;0)
