Freeview box - Waited for HDD, 2x Tuner, TOP-UP - is this OK ?
Discussion in 'Freeview & YouView' started by davidwatsonok, May 30, 2005.
  1. davidwatsonok
    davidwatsonok
    Jun 24, 2003
    1,311
    Yorkshire
    +136
    I've held off buying a Freeview box until there was one which will provide me with a PVR/HDD with twin tuners and have Top-Up capability. Saw this unit on another website and wondered what you guys think of it ?
    http://www.unbeatable.co.uk/CatalogueItem_26365.html
    Are there any other features that I should be looking out for, or any other machines that you would recommend over this with similar features ??
    Thanks, David.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It looks OK on paper. The acid test is how the software performs, and you will only find this out by reading independent reviews, and if this is a new box you won't see many of those yet.
    Another point to consider is just how useful the cam slots are going to be, since they are not cheap to add into the design. There are strong rumours circulating about the future financial viablilty of TopUp TV (E4 has already left their line-up), and if the company were to fail, how likely would it be that another pay service would follow in their footsteps ?
  3. Supernatural
    Supernatural
    Nov 15, 2003
    326
    Aldershot
    +5
  4. ChrisA
    ChrisA
    Jul 14, 2002
    162
    Suffolk, UK
    It looks interesteing but the blurb's a bit misleading surely? It can't be possible to "Record two channels and watch two channels all at the same time" with only two tuners unless they're the same two in which case why bother?
    C
  5. Paul Shirley
    Paul Shirley
    Sep 27, 2004
    1,354
    63
    +174
    Can't tell you if the Topfield can do that but it *is possible*. Each tuner grabs a multiplex with several channels on it, in theory you can simultaneously view or record all the channels on each multiplex. Some PVR's can record whole multiplexes.
    Decoding them is a bit harder and I'd only seen claims of record 2 + view 1 for the Topfield.
  6. davidwatsonok
    davidwatsonok
    Jun 24, 2003
    1,311
    Yorkshire
    +136
    Thanks for the replies and links. It looks a superb machine. Not too sure about all the downloadable fix's, updates and features as I run Apple Mac and they seem to require Windows :censored: Possibly worth waiting a little longer for all the current updates to be built in to the machine at POS, or will the retailer consider doing them prior to shipping :lease: I really just want it to run great from plug-in and not have to do anything else except use the bu99er, otherwise I'll have to bug a PC owning friend to D/L the updates and drag the thing over to their house :thumbsdow or buy an old Windows Lappy :eek: or maybe VPC in OSX :boring:
    Anyway, cheers :hiya:
