freeview box to replace philips dtr1500
Discussion in 'Freeview & YouView' started by rozzar, May 2, 2005.
  1. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    the box is giving me a lot of blocking. its about 18 months old now.
    what boxes are there on the market that would be an improvement? I would have gone for a Sony D800 instantly but i NEED s-video out through the scart (it goes through a tv tuner card on my pc)
    any suggestions?
  2. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    The Sony will do s-video from both of its SCART sockets. It can be selected manually for the TV SCART but must negotiate by Smartlink for the video SCART. Which socket are you refering to?
  3. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    The Sony, you can't buy a better box imo and it does s-video via scart.
  4. guylj
    guylj
    Feb 20, 2005
    47
    The Philips DTR1500 has a very good tuner and very good resistance to impulse interference. Some people say it is much better than the Sony in this respect. So if you are suddenly getting blocking having had good reception previously then while it is of course possible the DTR1500 has developed a subtle fault, I would be inclined to take a look at your signal quality before spending on a new box. You can get a very rough idea of signal levels and quality from the tuning menu but that would only be useful if you knew what your levels were when reception was OK. It's worth checking your aerial is still correctly aligned and all plugs and connectors are fitting tightly. It could even be something like the tree growth we start to get in Spring getting in between your aerial and the transmitter and attenuating the signal.
