Freeview box that outputs vga ?
Discussion in 'Freeview & YouView' started by ted26, Nov 24, 2004.
  1. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    Anyone seen or heard of a freeview box that outputs vga ?
    If so where can i find one !
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
  3. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    Cheers that sorts that question david :)
    So does anyone know if i can get a freeview box that outputs svhs to my pwd5 ?
  4. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
  5. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    Thats just what i am looking for david :thumbsup:
    I have sky through dvd recorder on component and am wanting another feed upto plasma so i can watch one whilst recording the other !
    The netgem seems cheaper than going the rgb/vga route
    thanks for your help :smashin:
  6. kim@cheung1957
    kim@cheung1957
    Aug 29, 2004
    17
    Can u tell me how to get component output (buy what cable to convert?)from the netgem so that i can connect to my ptae100. Thanks
    Danny
  7. Loafer316
    Loafer316
    Apr 8, 2003
    330
    As far as i understand it's a scart to componant (3 RCA) cable and you change the settings on the netgem to output componant.
    I have yet to plug mine in! as i havn't bought the cable either! don't know whether these cable are directional or not.
  8. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    I have had the netgem ouputting from component and it works fine but i saw no difference between that and scart ! (had a netgem last year)
    And if remember you have to make sure the scart to component cable is going in the right direction :)
  9. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Can anyone recommend a cable? or where they bought theirs? :zonked:
  10. brifobwad
    brifobwad
    Nov 29, 2002
    68
    11
    Rosyth
  11. heidi_ni
    heidi_ni
    Is those freeview receiver can be used in Australia?
