Freeview Box - Sony D800 and D800U - difference?
Discussion in 'Freeview & YouView' started by BigG, Jul 17, 2005.
  1. BigG
    BigG
    Jul 17, 2005
    Hi all,
    Can anyone advise what the difference is between the Sony D800 and D800U freeview boxes are? I suspect it's something to do with the over-the-air updates, but I want to be sure before I buy.
    Many thanks
  2. Maff et1
    Maff et1
    AFAIK (and sonys website) there is only one - the VTX-D800U - the U just seems to signify the intended country (U for UK, D for Germany etc)
