Freeview better bit rate
Discussion in 'Freeview & YouView' started by PHOTOSHOP KID, Sep 9, 2009.
  1. PHOTOSHOP KID
    PHOTOSHOP KID
    Nov 13, 2005
    1,515
    +162
    Can we expect to get a higher bitrate on Freeview when the switch over takes place?
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    I'd be happy with a stable picture in the first place. At this point in time for me, digital tv tranmitted in ALL its forms has been a huge disappointment; so much so I have all but stopped watching. :thumbsdow I do believe there are big changes soon in my area (northwest) including an increase in transmitter power but ill just have to wait and see. I do not expect any improvement in quality just more dross channels.
  3. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    23,991
    Redditch
    +4,090
    No quite the reverse, removing a Mux for HD will reduce bandwidth so bit rates will have to be reduced, hopefully more advanced encoders will help. A change for Mux 1 to 8K mode will allow more channels to be shoehorned onto this mux at dso
  4. Phorteous
    Phorteous
    Jan 24, 2009
    104
    +12
  5. KMO
    KMO
    Nov 4, 2004
    431
    28
    Cambridge
    +56
    Rather dodgy headline writing there for the sake of exaggeration - the new Mux 1 will have 33% less capacity than the current Mux 1 and B pair, but it won't be carrying as many channels.
    Certainly a reduction, but not 33%.
  6. reslfj
    reslfj
    Sep 20, 2007
    44
    +7
    No, the 8k mode will do nothing, but make the signal better for SFN's and more robust to impulse noise only. It will not allow higher bit-rates - Period.
    The much higher power at DSO will both enable the 64-QAM mode (adding 6 Mbit/sec) and make the signal much more robust.
    But in this case the advise is wrong, very, very WRONG.
    With the new MPEG-2 encoders and stat-muxing that the BBC is/will be using plus moving one BBC channel to MUX2/PSB-2, you may end up with better picture quality.
    The total SD bit-rate are 120 Mbps on 6 muxes pre-DSO. The SD bit-rate will be 120 Mbps on 5 muxes post-DSO.
    On top of this comes the 36 Mpbs for the PSB-3 HD mux post-DSO.
    Lars :)
  7. sulphh
    sulphh
    Sep 11, 2009
    17
    More freeview woes :( Can barely get an image nowadays.
