Freeview best PQ?
Discussion in 'Freeview & YouView' started by hoyin, Jan 23, 2005.
  1. hoyin
    hoyin
    It is quite a simple question.
    I have a Netgem iPlayer.
    Would I get the best PQ from it using component out to my LCD
    Or could I get an even better picture using a HTPC to receive the Freeview and output via DVI into my LCD?
    Thanks,
    Ho yin
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    It depends on what video processing the HTPC is doing, and how well. If it has a good quality scaler then it should be better than the internal scaler of the LCD screen.
    If you already have the HTPC then try it and see. If you are just thinking about building/buying a HTPC then ask about the hardware/software that is recommended on the HTPC forum here.
    Mark.
